Clutch Cover Gasket?
As I understand the process by reading through the '26 service manual, to
change out the motor, the clutch cover bolts and the bell housing bolts are
removed, allowing the transmission (complete with the clutch assembly pinned
to it) to be withdrawn from the flywheel. Assembly is the reverse of
disassembly.
Are there any tricks to know? Do I need a gasket or can I get away with
some of this new miracle hylomar blue silicone non-setting sealer such as is
used on some of the latest cars? You know, the ones with surfaces so exactly
machined as to eliminate the need for gaskets? Are there any distance issues
involved? If a gasket is required, how thick should it be and made of what
material?
Paul O'Neil, Hudson29@aol.com
NEW email list for Hudson Super Six Cars, 1916-1929!
http://www.onelist.com/subscribe/HudsonSuperSix16-29
1926 Hudson Anderson Bodied Coupe
1926 Hudson Parts Car "The Grapes Of Wrath"
1928 Hudson Roadster Project
1929 Hudson Town Sedan
1939 Cadillac Coupe (How'd that get in there?)
Fullerton, California USA
AEROMARK - Need Rubber Stamps or Signs? See:
http://www.aeromark.net
disassembly.
material?
