Re: [HSS] Freeing the Hudson Clutch
Hudson29@aol.com wrote:
Paul remember what I said before, make sure you depress the clutch>
> My poor ole '26 Coupe been sitting inactive for most of the last five
> years. There are a series of reasons for this, but in any case it has often
> been a year or so without driving. When this happens, the clutch can be very
> difficult to free off.
> I am familiar with this problem from many years experience with British
> motorcycles. It has become part of the starting drill -- each morning, pull
> in the hand clutch and take a swing on the kickstarter. The plates offer a
> little resistance to the leg and then give in to doing their work.
> I have been adapting that procedure to the Super Sixes. First, get the
> car running and warm with the gearbox in neutral. After it is warm enough to
> want to start readily, I would kill the motor, select first or reverse
> (depending on which direction had more room), set the hand throttle up a bit,
> depress the clutch pedal to the floor, hit the starter pedal to start the
> motor and then stomp the brake HARD with my size 14.
> The poor ole girl gives a shudder and a shake, but the clutch does free.
> I HATE doing it this way! I imagine all sorts of mayhem both from the abused
> mechanical bits and from anything I might hit should my boot not find the
> brake pedal in time. There has got to be a better way!
> Last night I was preparing the Coupe for it's new motor and to do that it
> had to be ferried from it's storage garage about two miles to the back of the
> shop where the transplant is to take place. That means the clutch had to be
> freed once again after sitting more than a year.
> The back axle of the car was already up on jackstands so I could get out
> and get under to work on a fuel feed problem so it seemed a good idea to run
> the car in gear up in the air and just slowly "clamp" down on the brakes.
> Once again I selected first to aim toward wide open spaces should something
> go amiss and went ahead and fired up the motor. Starting the car in gear with
> the wheels flailing away proved no trauma at all. So far, so good.
> Next, the clutch was depressed, then eeeeassse on the brake . . . a bit
> more hand throttle to keep the motor from stalling and . . . the clutch freed
> with a minor jerk! Hey, that's not too bad! I'm gonna hafta remember that
> trick for the next time the clutch wants to play hardball with me. It's a
> little extra work, but seems easier on the mechanicals and therefore easier
> on me.
> NEW email list for Hudson Super Six Cars, 1916-1929!
> http://www.onelist.com/subscribe/HudsonSuperSix16-29
> 1926 Hudson Anderson Bodied Coupe
> 1926 Hudson Parts Car "The Grapes Of Wrath"
> 1928 Hudson Roadster Project
> 1929 Hudson Town Sedan
> 1939 Cadillac Coupe (How'd that get in there?)
> Fullerton, California USA
> AEROMARK - Need Rubber Stamps or Signs? See:
> http://www.aeromark.net
> Community email addresses:
> Shortcut URL to this page:
before turning the engine off so that the oil can get in between the
plates as the motor is still turning. This should overcome the problem
to a large extent.
Geoff.
