External Contracting Brake Lining
With the new motor/clutch project proceeding currently, it is time to
look down the road just a little bit. The brakes on the '26 are in poor
shape. When applied, they pull unevenly, shudder and fade after very little
use. The brakes on the car may have the original linings that Hudson
installed in November of 1926.
What lining should be used, and where can it be found? I have heard that
at least some of the current linings are too hard and don't work well. Others
say "asbestos" linings are best. What do you fellows use on your mid twenties
cars?
Is there an axle seal that should be replaced at the same time to keep
the new linings safe and dry?
I have an original 1929 Motor's Manual that lists the following specs for
the linings:
Manufacterer - Raybestos
Length - 44 1/2"
Width - 2 1/2"
Thickness - 3/16"? (Type too small to print clearly)
Clearance - 1/32"? (Type too small to print clearly)
Can anyone verify these dimensions?
Paul O'Neil, Hudson29@aol.com
Fullerton, California USA
NEW email list for Hudson Super Six Cars, 1916-1929!
http://www.egroups.com/group/HudsonSuperSix16-29
1926 Hudson Anderson Bodied Coupe
1926 Hudson Parts Car "The Grapes Of Wrath"
1928 Hudson Roadster Project
1929 Hudson Town Sedan
1939 Cadillac Coupe (How'd that get in there?)
AEROMARK - Need Rubber Stamps or Signs? See:
http://www.aeromark.net
cars?
the linings:
Length - 44 1/2"
Width - 2 1/2"
