Re: [HSS] External Contracting Brake Lining
Hudson29@aol.com wrote:
Those specs look O.K. A local member used Kevlar linigns on his Essex>
> With the new motor/clutch project proceeding currently, it is time to
> look down the road just a little bit. The brakes on the '26 are in poor
> shape. When applied, they pull unevenly, shudder and fade after very little
> use. The brakes on the car may have the original linings that Hudson
> installed in November of 1926.
> What lining should be used, and where can it be found? I have heard that
> at least some of the current linings are too hard and don't work well. Others
> say "asbestos" linings are best. What do you fellows use on your mid twenties
> cars?
> Is there an axle seal that should be replaced at the same time to keep
> the new linings safe and dry?
> I have an original 1929 Motor's Manual that lists the following specs for
> the linings:
> Manufacterer - Raybestos
> Length - 44 1/2"
> Width - 2 1/2"
> Thickness - 3/16"? (Type too small to print clearly)
> Clearance - 1/32"? (Type too small to print clearly)
> Can anyone verify these dimensions?
> Fullerton, California USA
> NEW email list for Hudson Super Six Cars, 1916-1929!
> http://www.egroups.com/group/HudsonSuperSix16-29
> 1926 Hudson Anderson Bodied Coupe
> 1926 Hudson Parts Car "The Grapes Of Wrath"
> 1928 Hudson Roadster Project
> 1929 Hudson Town Sedan
> 1939 Cadillac Coupe (How'd that get in there?)
> AEROMARK - Need Rubber Stamps or Signs? See:
> http://www.aeromark.net
> Community email addresses:
> Shortcut URL to this page:
4, and they are incredibly good, no fade or lock-up, and work when wet
as well. You will have to check with brake specialists over there for
availability of this material.
Geoff.
- 81 Hudson 8
