29 Clutch Throwout "Collar"
In cleaning and painting bits and pieces from the '29 clutch/transmission
assembly, I ran across a machined cast iron "collar" that slides on a bush
surrounding the transmission input shaft. It's purpose is to communicate
motion from the throwout fork to the throwout bearing.
The collar has a set screw that looks like it should ride in a slot
machined in the bush that the collar rides on. Is this correct? If so, this
one is WAY out of adjustment, being 1/8" shy of being flush with the inner
surface of the collar. To ride in the slot, it would have to be deeper yet.
Is there perhaps another little piece that the set screw pushes into the
slot? How should this assembly be setup and adjusted?
Paul O'Neil, Hudson29@aol.com
Fullerton, California USA
NEW email list for Hudson Super Six Cars, 1916-1929!
http://www.egroups.com/group/HudsonSuperSix16-29
1926 Hudson Anderson Bodied Coupe
1926 Hudson Parts Car "The Grapes Of Wrath"
1928 Hudson Roadster Project
1929 Hudson Town Sedan
1939 Cadillac Coupe (How'd that get in there?)
AEROMARK - Need Rubber Stamps or Signs? See:
http://www.aeromark.net
