Re: [HSS] 29 Clutch Throwout "Collar"
Hudson29@aol.com wrote:
Paul, if you look on page 8 of the '29 owner's manual, I think you will>
> In cleaning and painting bits and pieces from the '29 clutch/transmission
> assembly, I ran across a machined cast iron "collar" that slides on a bush
> surrounding the transmission input shaft. It's purpose is to communicate
> motion from the throwout fork to the throwout bearing.
> The collar has a set screw that looks like it should ride in a slot
> machined in the bush that the collar rides on. Is this correct? If so, this
> one is WAY out of adjustment, being 1/8" shy of being flush with the inner
> surface of the collar. To ride in the slot, it would have to be deeper yet.
> Is there perhaps another little piece that the set screw pushes into the
> slot? How should this assembly be setup and adjusted?
see this "set screw" which is actually a tapered plug, which is removed
for lubricating the throw-out bearing. In practice this lubrication is
usually not done, as there is enough clutch fluid around to provide
lubrication for the throw-out bearing.
Geoff
