Re: [HSS] 1919 clutch problems
rockingchair@tcsn.net wrote:
***There are 8 driven cork-insert discs.
> I finaliy pulled the clutch on the 1919 touring, and since my
> books on hudsons don't go back far enough I need some HELP.
> First question:
> How many driven and drive discs are supposed to be??
> Second:***Yes.
> Is the throwout a bronze bushing on steel???
> This bushing seems to fit into a "pocket" that is about 1/4 deep.***Most likely worn.
> Is this correct or is there a part missing (perhaps carbon) or is
> the sucker worn out??
> The reason the clutch was removed was because it took two***You should be able to transplant the later unit directly, but will
> men and a small boy to depress the clutch pedal.
> I have a clutch from a 25 and it is NOT in any way like the 19
> clutch.
have to use the throuw-out bearing and all.
> Also where can I get the buttons recorked??***Doug Wildrick - drdoug@indy.net can do these, or if you want to
pay postage to New Zealand, I can do them. This is a time-consuming
job, as there are over 300 corks, and each plate has to be trued, corks
inserted, dressed, and heat compressed.
> Hudsonless BillIt looks like we're stuck with Yahoo. I had no trouble changing over
> (PS I want the old e-groups back ....Do not care for the yahoo
> registration (or maybe I am DUMB about there questions
however. Answers to your questions inserted above with ***
Geoff
