Flywheel Timing Marks
At some point in the distant past, some humorless bustard machined off
the ring gear teeth on my old '29 flywheel and installed a new ring gear. I
call that unknown person a humorless bustard for two reasons.
First, they seem to have cut the flywheel down too much and used shim
stock unevenly to tighten the resultant gap. The cranking system worked fine
on this '29 engine, so I'll probably have no worries using the same setup on
the '26.
The second reason for the name calling involves the timing marks. When
they cut off the old teeth, the marks went with them, and the bright boys
didn't bother to rescribe or repunch them! This caused a pal of mine and I a
certain amount of consternation trying to locate the nonexistent marks by
looking through the timing hole and hitting the starter pedal. Removing the
flywheel cover and using a flywheel wrench revealed the ugly truth, and the
motor was timed by ear which seemed to work out fine.
What to do now? The flywheel is off, freshly painted and ready to be
remarked, but where should the marks go? The only current marking looks like
this:
Is that mark significant? The only other way I can think of to mark the
wheel would be to "copy" the marks from the '26 wheel. To do this it will be
necessary to figure out a reference point common to both wheels (like the
"offset" mounting stud) and count off the number of teeth. I had in mind
punching a dot and paint filling it with white to make it stand out against
the pointer.
Does anybody have any comments about this? Is there an easy way to
determine which stud is the "offset" one? I had in mind using graph paper to
spot the "offset." Should the marks go back in the factory locations or
"advanced" some? What tool should be used to make the marks?
Paul O'Neil, Hudson29@aol.com
Fullerton, California USA
NEW email list for Hudson Super Six Cars, 1916-1929!
http://www.egroups.com/group/HudsonSuperSix16-29
1926 Hudson Anderson Bodied Coupe
1926 Hudson Parts Car "The Grapes Of Wrath"
1928 Hudson Roadster Project
1929 Hudson Town Sedan
1939 Cadillac Coupe (How'd that get in there?)
AEROMARK - Need Rubber Stamps or Signs? See:
http://www.aeromark.net
the '26.
this:
the pointer.
