Reference Book Hudson Super-Six First Edition
Guys - found this amongst my "stuff" thus believe it to be of 1916.
It is 71 pps. long. Inside the front flap a 1 p. pullout illus. of
the rear axle; on p. 14 is an illus. of the dash & all it's
components & there is a description on how to start the engine; p. 16
an illus. of the engine & specifically the carb.; p. 17 a close up of
the valve area with cover removed & shows/tells how to adj. valves &
shows proper orig. equip. tools to be used in doing so; p. 23 an end
view of the engine & discussion & illus. of oiling system.; p. 25 an
a illus. of the clutch, pedal, with description of how to adjust
properly, etc.; p. 29 1/2 p. drawing with " " " " "
the brakes; p. 31 shows an entire chassis to illus. the fuel system
highlighting the gas tank, vac. tank, carb., & int. manifold & p. 32
a cut-away view & explanation of how vac. tank works; ppw. 34 & 35
are cut-aways of the carb., it's parts, & explanation; pps. 36-7 are
typical lubrication chart of chassis; wiring diagram on p. 52, close
up of generator on p. 53 with illus. of brushes on gen. & starter on
pps. 54 & 55; p. 57 is top of the dist. with cap off, text with
discussion thereof; "Automatic Advance Governor" shown on p. 58; p.
60 wiring dia. showing wires to dash switches; & on p. 67 "Charging
Circuit Diagram". Altho book fragile in fairly good condition. If
interest in this book will give it to someone you choose for making
it avail. on CD, posted to file here, or ??? Post your thoughts here.
