Re: [HSS] What Lubricants?
Hudson29@aol.com wrote:
Both the transmission and rear end should have 140 grade. The steering>
> It will be time to add fresh lubricants to the project Super Six motor,
> trannie and rear end in the next week or so. I have been using 20-50W in the
> motor and straight 90W in the box and punkin. What SHOULD I use? Hudson calls
> for "medium heavy bodied oil" for the motor "high grade light bodied
> transmission oil" and "good rear axle or differential oil" for the rear end.
> Models As use a 600W oil in the boxes and rear end, is this too thick?
> What about 140W? Is 10-40 too thin for the motor?
> Fullerton, California USA
box should be 600W. For running in the motor I would recommend a
straight 30 grade for 1000 miles, then change over to a 20W-50
multigrade. You probably have different oils there than we have here,
but I use Castrol GTX in all my cars.
Geoff.
Geoff.
