Re: [HSS] Crankcase Cleaning
Hudson29@aol.com wrote:
I use a mixture of kerosene (parrafin?) and ordinary household detergent>
> In a message dated 4/5/01 5:41:16 AM, GTBirdsall@webtv.net writes:
> << I
> took the rods and new pistons to the machine shop yesterday to have them
> hang them for me. The rods were bushed to accommodate the smaller rist
> pins. I should have them back next week and can start reassembling. I
> need to start cleaning the aluminum crank case. After years of baked on
> oil and grease it will take awhile. >>
> How do you plan to clean the crankcase? The '26 was bead blasted, and
> while the nice snowy AL looks pretty sharp, it is almost certainly the wrong
> finish. The gearbox has a different look, shinier and more uneven. I see no
> reason to suppose that the crankcase should look any different from the
> gearbox. The glass bead finish will probably prove difficult to keep tidy.
> On British motorcycle crankcases there are a number of ways to sharpen
> them up. One fellow swore by Simple Green cleanser, another used an old
> electric turkey roaster and some sort of solvent to steam the parts clean. I
> use LOTS of lacquer thinner and scrubbing with a brush. Has anybody else got
> any ideas to make this messy job go easier? I wonder if steam cleaning might
> do the trick.
> Fullerton, California USA
with a wire brush. This leaves the original rough finish of the
crankcase, and cleans out all the dirt and grease. Then it can be
hosed off with high pressure water, preferably a water blaster, but
ordinary garden hose will do. I use a cup full of dertegent to a
gallon of kerosene, and stir it up constantly to keep mixed. The
detergent acts a dispersant so the water can then wash everything off.
An alternative would be to use a commercial degreaser which can also be
hosed off. Just to cheer you up, there is no easy way! I have seen
these crankcases and water pump housings taken to with a disc sander and
highly polished, which looks nice, but certainly does not look original,
and is over-restoring in my opinion. I like things to look as they
came from the factory.
Geoff.
