Speedo Cable Repaired
Attachments :
Thanks to the advice of John in AU, I repaired the speedo cable this past
weekend. It was kinked when the old motor came out and looked to be a goner.
The repair was simple enough. A bit of old tin can was cut into a
rectangular shape. It was bent into a tubular shape using a 3/8 ratchet
extension and a small ballpeen hammer. After wrapping the metal tube around
the kinked portion of the cable, two fuel line hose clamps were tightened
around the edges and the kinked area is now straight if somewhat stiffer than
it used to be. A coat of chassis black paint finished the job.
Next the inner cable needs to be lubed and installed and the cable
reinstalled in the car. I have heard that there is a special speedo cable
lube to use and that regular grease is not the right stuff. Has anybody got
any info on this? If not, I'll just lube it up with wheelbearing grease and
have done with it.
have done with it.
