Modern Gen Mod
In a message dated 4/18/01 1:58:39 PM, geoffclark@xtra.co.nz writes:
<< The
regulator mounts on the bulkhead and the wires go along the high-tension
wire tube, and hey-presto, you have a better generator set-up with
automatic charging rate. >>
A very clever mod! A previous owner of my Coupe had taken the factory
cutout off and hidden a voltage regulator up under the dash. The modified
charging system worked pretty well. My new motor has a generator with the
original style cutout and I can either remove the regulator and retain the
cutout or modify the existing generator/cutout system to use the regulated
system. Any comments about this? What needs to be done to the gen/cutout to
use the regulator?
Paul O'Neil, Hudson29@aol.com
Fullerton, California USA
NEW email list for Hudson Super Six Cars, 1916-1929!
http://www.egroups.com/group/HudsonSuperSix16-29
1926 Hudson Anderson Bodied Coupe
1926 Hudson Parts Car "The Grapes Of Wrath"
1928 Hudson Roadster Project
1929 Hudson Town Sedan
1939 Cadillac Coupe (How'd that get in there?)
AEROMARK - Need Rubber Stamps or Signs? See:
http://www.aeromark.net
<< The
use the regulator?
