Re: [HSS] Clutch Adjustment
Hudson29@aol.com wrote:
So how much free-play do you have with the adjustment screwed all the>
> I had worked my vectors wrong and made the clutch further out of
> adjustment by lengthening the link as I thought I should. A quick change had
> the link shortened as much as it would go and this did improve the action of
> the pedal. The problem is that I ran out of room to shorten the link before
> all of the free play was taken up. The threaded shaft hits the loop on the
> pedal if it is brought in even one more turn.
> It would seem that I will have to grind 1/4" to a 1/2" off of the link to
> make it work. Surely this can't be right? I checked and I had used 1/32"
> material to make the clutch gasket, not 1/16". Would this make the
> difference? Looking at the link, there really doesn't seem to be any reason
> why grinding a bit off would hurt anything. Can anyone think of any problems
> that might arise? Unfortunately, it will be another week before I can get at
> this project again.
> Fullerton, California USA
way in? The thing is to have a MINIMUM free-play of 1". So if the
clutch disengages freely and operates okay, more free-play than that
doesn't matter. There will be a run-in period when the corks wear in a
little, so don't worry too much if you haven't got it exactly right
initially. Also, I have found that the actual throw-out yoke fingers are
usually worn, which exacerbates the problem. The gasket was originally
1/16", and I have found with this thickness that when the corks are worn
out the clutch will slip before the pressure plate contacts the alloy
disc, hence eliminating of damage. With a thinner gasket the clutch
will still grab until the corks are so worn that the pressure plate will
start scoring the alloy disc. However, I doubt if you are ever going
to do enough miles to wear the clutch out, so probably easier to leave
as is.
Geoff.
