Re: [HSS] Speedo Cable Repair Finished
Paul, your engine looks great S/S studs,green paint etc. but you will
have to do something with the rusty exhaust manifold. Some people
here have had their manifolds sprayed with Alum. metal spray or had
a special heat resistant coating applied, looks better than a rusty one
I am not sure what to do with mine. The photos are excellent.
John.
John.
----- Original Message -----
Sent: Tuesday, April 24, 2001 11:59 AM
Subject: [HSS] Speedo Cable Repair Finished
> Thanks to the advice of my friend Neil, I whipped up a batch of stuff
I
> call "Snot On A Doorknob" because it is so slippery. A smidgen of graphite
> was mixed with two plops of Vaseline and the resultant black oozy mess was
> slathered onto the inner cable which was then slipped into the outer
cable. I
> was afraid there might be a snag where the outer cable was repaired but
this
> proved not to be the case.
> It was easy to find the right position to install the cable into the
> transmission as I could see it, but the instrument end proved a different
> matter. I fooled with it for a while and then just screwed the collar down
> hoping it would find it's own home. The collar screwed all the way down
> without apparent distress, so maybe something is spring loaded and the
cable
> end will pop into place on it's own. We shall see when the car is on the
> road! A pic of the repaired portion as it is installed is attached.
> Fullerton, California USA
> NEW email list for Hudson Super Six Cars, 1916-1929!
> http://www.egroups.com/group/HudsonSuperSix16-29
> 1926 Hudson Anderson Bodied Coupe
> 1926 Hudson Parts Car "The Grapes Of Wrath"
> 1928 Hudson Roadster Project
> 1929 Hudson Town Sedan
> 1939 Cadillac Coupe (How'd that get in there?)
> AEROMARK - Need Rubber Stamps or Signs? See:
> http://www.aeromark.net
> Community email addresses:
> Shortcut URL to this page:
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
