Re: [HSS] The Switch Is Apart
Hudson29@aol.com wrote:
Do you have anyone who can reproduce the switch arms for you? If not I>
> Thanks to a suggestion on this list, I tried prying the rotary switches
> from the handles of the by now infamous "Mien Car" electrical switch. A
> little pressure produced a wiggle, enough to confirm that the barrels would
> separate at the base.
> The parts were spritzed with Aerokroil and the circular bits were prized
> off. The handles were swollen and slightly stuck into the face of the switch,
> so they were tapped out with a drift. This needed enough force to give me
> qualms about the probability of the deteriorated pot metal being damaged, but
> this turn out not to be the case. Removing the rotary portion allowed a
> larger punch to be used than would have been the case had they remained in
> place.
> The two handles look to be identical, a bit of a break. Now they are off,
> it is easy to see the deep crack that had weakened the metal. If my head
> hadn't broken the handle a couple of weeks ago, my hand certainly would have
> on using the switch sometime in the future.
> A pic is attached showing the parts laid out. More detailed shots have
> been posted to the Files section.
> Fullerton, California USA
can get them done at the same foundry who did the steering wheel hubs.
This would entail sending them around the world and back however.
Incidentally, I have your rose-pattern radiator cap almost ready, so
will post that to you in the near future. I have found one side only
of the rose pattern robe-rail brackets.
Geoff.
