Exhaust Manifold Mods
In a message dated 4/27/01 2:38:56 PM, geoffclark@xtra.co.nz writes:
<< the easiest way to attach the exhaust is to weld a two-bolt flange to the
back of the manifold. This can be welded to the flange nut if it is till in
place. I use a nickel-iron arc electrode for this, welding 1/2 an inch at
a time starting in three different places and alternately moving around so
as not overheat either the work or the electrode. Then you can weld a
corresponding flange on to the exhaust pipe and your connection problems are
cured forever. Why did Hudson use those hopeless threaded flanges? They
were extremely difficult to pack tight. >>
Quite a few of the old cars did it this way. I doubt the makers ever
considered the car might last 10 years much less 100.
I wonder if a broken manifold might be repaired the same way you
described here. A lot of the mid twenties manifolds are broken right at the
downturn.
Paul O'Neil, Hudson29@aol.com
Fullerton, California USA
NEW email list for Hudson Super Six Cars, 1916-1929!
http://www.egroups.co.uk/group/HudsonSuperSix16-29
1926 Hudson Anderson Bodied Coupe
1926 Hudson Parts Car "The Grapes Of Wrath"
1928 Hudson Roadster Project
1929 Hudson Town Sedan
1939 Cadillac Coupe (How'd that get in there?)
AEROMARK - Need Rubber Stamps or Signs? See:
http://www.aeromark.net
downturn.
