Clutch Link
Attachments :
The attached pic shows the problem with the clutch link on this 1929
clutch assembly fitted into the 1926 car. From the flywheel back the only
components that were not in the old rig are the pilot bearing, the recorked
disc and the clutch cover gasket.
Nonetheless, the link would not contract enough to take up the slack in
the mechanism, so I crawled under to look up and make sure the throwout pilot
bushing had not slipped out of place in the fork. Having satisfied myself
that all was well, the link was removed to meet it's destiny with the bench
grinder.
Nobody on this list had raised an alarm when I first proposed this
Draconian remedy, so with no fear of decayed teeth or impotence, the link's
fate was sealed. It didn't occur to me to measure the length before and
after, but something on the order of 3/8" was removed overall. The pedal now
has a good 1" play before the initial slack is out, and another 1" or so
before the pressure builds.
The pedal feels like it stands a chance of releasing the clutch, but only
a trial with a running motor will tell for sure. More material could easily
have been removed to tighten up the action, but it seemed best to just remove
the minimum and await test results.
Paul O'Neil, Hudson29@aol.com
Fullerton, California USA
NEW email list for Hudson Super Six Cars, 1916-1929!
http://www.egroups.co.uk/group/HudsonSuperSix16-29
1926 Hudson Anderson Bodied Coupe
1926 Hudson Parts Car "The Grapes Of Wrath"
1928 Hudson Roadster Project
1929 Hudson Town Sedan
1939 Cadillac Coupe (How'd that get in there?)
AEROMARK - Need Rubber Stamps or Signs? See:
http://www.aeromark.net
grinder.
