Throttle Linkage
Attachments :
After a fruitless search high and low for a usable 10-32 swivel
connection, the only alternative seemed to be some sort of bodge. It would be
necessary to make the 1/4-28 one that Restoration supply sells work with the
stock 10-32 clevis end that takes the proper size pin to fit in the throttle
cross shaft bellcrank.
The local hardware store was tapped for a length of 1/4" steel round
stock in a 3' long size. The round stock was cut to stock length with a
hacksaw and the end was ground down by hand on the handy-dandy ole bench
grinder. I used one of those useful little plastic nut and bolt sizers for a
guide as to size. When the rod would just pass through the #10 hole, it
turned out to be perfect for the threading die. Amazingly, threading went
easily and I had to wonder why I had fretted so much about this job. Keeping
the round stock moving and frequent checks helped the jod to go along
smoothly.
Indeed, I relaxed so much that I didn't get the 1/4-28 die on straight on
the other (easy) end and it cut the threads a little off center. Oh well, you
won't tell anybody will you?
The new throttle control rod fit like a factory job and needed only a
small adjustment for length was needed. Unless you REALLY know these cars,
there would really be no way to tell it is not a factory part. A pic of the
ground end is attached.
Paul O'Neil, Hudson29@aol.com
Fullerton, California USA
NEW email list for Hudson Super Six Cars, 1916-1929!
http://www.egroups.co.uk/group/HudsonSuperSix16-29
1926 Hudson Anderson Bodied Coupe
1926 Hudson Parts Car "The Grapes Of Wrath"
1928 Hudson Roadster Project
1929 Hudson Town Sedan
1939 Cadillac Coupe (How'd that get in there?)
AEROMARK - Need Rubber Stamps or Signs? See:
http://www.aeromark.net
smoothly.
