Rear Axle Bumpers
Attachments :
It took a long time,
but I found the original axle bumpers for the 1926 Hudson - which are now as
hard as a rock. But you can see the shape from the pictures below-
unfortunately the flash wiped out the tape measure so here goes. All
measurements are approximate as I have no idea if they shrunk with age.
They are 3 inches across 2 1/2 inches high the hole is 1 inch and
the two small cuts in the top are between 3/16 and 1/4 inch wide. The
larger cuts in the top from edge to edge (looks like part of a circle) are 5/8
inches.
inches.
Hope that
helps.
helps.
Tony
