Oil pump
Attachments :
In HudsonSuperSix16-29@e...,
Hudson29@a... wrote:
> I need a measurement from
> running or not. I have found a long control rod in a box of spare
> bits. It does not fit anything on
the '26, but will be perfect to cut down to
> make oil pump control rod.
> I need to know how
long to make it. Please measure the distance from
the
> center of the axis of the clevis end to the end of the threads on
the other long to make it. Please measure the distance from
the
> end. If you can't see the end
of the threads, the distance from pin to pin
> will tell me what I need to know. Thanks in advance!
I think that the oil
pump is the bottom lever and the top one controls the advance on the
distributor, but they are both in the picture. The top on is 17 1/16
center pin to center pin. The bottom one is 14 9/16 inches c to c.
The one that goes down to the gears is 3 7/16 inches. All measurements are
approximate and that is why they have adjustable clevis
ends.
ends.
Tony
