Head Torque
Attachments :
After having run the '26 Hudson engine the week before, it seemed a good
idea to check the head nuts again to see if there might be some movement.
Boy, was there ever! All of the nuts were shy of the 50 lbs I had left them
with, some began movement with as little as 30 showing on the wrench.
After getting them all snugged down, I started the motor and warmed it up
to a bit warmer than was comfortable to keep my hand on the water outlet
pipe, then had at them again. This hot setting produced more movement yet!
Next weekend I'll take it for a bit of a drive and get it thoroughly warm and
check the nuts again. I gotta expect that the gasket will settle even more,
but have to think we have got to be getting close to a permanent situation.
