1918 Super Six rod dipper
I removed a .004 shim today on the nbr. 4 conn. rod bearing cap.
I noticed that the oil dipper on that rod was different than the
other five rods. It was not as wide and almost comes to a point at the
bottom. The other type besides being wider are almost shaped like a
rectangle. Does anyone know which type was correct for 1918 and if it
is O.K. to mismatch them? I would guess that the pointed type that is
now on my nbr. 4 rod would not dip as much oil?
I'm putting the thing back together tomorrow, and hope that this will
cure a slight rod knock that comes in at around 25 mph.
Also, anyone know what the torque is on those rod caps. I can't find
anything in my shop manual on that. I did noticed that the torque on
the later 212 and 254 C. I. engines ( 1940) was around 45 lbs. per
Motors manual. P.S. I had .006 clearance before removing the shim.
Thanks for any info.
Dave Keister Seattle
