Re: [HSS] Original 28 Vacuum Tank?
Hudson29@aol.com wrote:
Yes, that is the correct '28 vacuum tank. The fuel tap is set above>
> This is the firewall of the '28 Coupe. Does anyone know if this vacuum
> tank is correct for a '28? I would have expected a standard Stewart Warner
> unit. What is this one Jeff? Note the two valves, one for the fuel line to
> the carbie, the other to drain the tank. A very nice setup. The original
> rubber grommets are still in place in the firewall, nice to see that they
> look pretty much the same as modern ones.
> Fullerton, California USA
the drain tap, to allow sediment, water etc. to accumulate in the
bottom, and is then drained off periodically.
Geoff.
