Re: [HSS] fan belt 1927 hudson
jjt39378@webtv.net wrote:
John, the fan arm clamps on to the post in the engine block, and the>
> hello again
> I had just replaced the fan belt on my 27 Hudson with a modern rubber belt
> (this could have been a mistake)
> I took the car out fr a spin when I hearda noise under the hood. The fan
> was spinning and hitting the radiator
> the fan was flush against it! So my question is what stops this from happening. I can see no retainer on the shaft to stop it. No nut at the end of the shaft. And if it is broken,
> do I have to pull the radiator to get it out? As you can see, I need help
> Any kind of help thanks John T
spindle is screwed in from the back. What came loose? I can't see any
problem if everything is done up tight.
Geoff.
