Re: [HSS] Original Parts
Greetings Hudson club members , I am in the uk and am trying to source a 26
" wheel rim for a freinds hudson it of the detachable type . is there only
one make fitted to these cars? we are trying to identify the vehicle but
there seem to be lack of ident ification it would help if u could tell me
where to look for the chassis number or type number. i could then let
you have it to try to source this part thanking you in
anticipationPeterKWest
----- Original Message -----
Sent: Sunday, July 29, 2001 4:01 AM
Subject: [HSS] Original Parts
> On the recent subject of u-joints an interesting point was raised.
> MODIFICATION. Do you retain what was origanal or do you modify as
> best you can? If your u-joints need replacing, do you insist on
> original parts? What if they aren't available? Do you park the car in
> the garage? Do you have original u-joints re-made at an exorbant cost
> or do you have some machine work done to accomadate modern parts?
> I will scrifice originality for saftey when it comes to items like
> glass, tires, lubrication and lighting, but what about the "other"
> things? My standard is "just cause". If a part is weak from the
> begining or the original is not obtainable at a resonable cost, is
> there just cause for subsituting a modification? Long ago I realized
> that I could not return a car to its ORIGINAL (as it rolled from the
> production line) state. I tend to look at the issue from a case by
> case basis. If I can replace an original part, so much the better.
> However, if the part is unobtainable or was bad from the get-go, I
> will modify as needed to keep my Hudson on the road.
> Community email addresses:
> Shortcut URL to this page:
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
