28 Hudson Oiling/Bearings
Hi, Paul.
I have learned a bit about the super six engine. It is a tough
engind, but to do the Great American Race with the orignal splash
oiling system would be to waste a good engine. The crank has been
drilled for oiling, hard chromed and ground to size. Main and rod
bearings have been refitted with insert bearings. Oil lubricates and
cools in the engine and splash is not sufficent for the high loads
and long run times we give the cars. A race car on the track has it
easier because of the shorter time it runs.
I did not do the actual modification of the engine, just trouble
shoot it and keep it working. We must do some further improvements on
the oil pump drive and seal portion, but the basics are correct.
We may add an oil squirter to the front cover putting oil directly on
the auxillary shaft drive to cool and lubricate it. The orignal
bronze part has a self lubricating effect against steel. The
replacement steel part will need just a bit of protection.
Just as a thought, I suspect the additional load of the oil pump on
the auxillary shaft drive may have contributed to it's failure, even
though they are a weak link in orignal configuration.
I too dislike modifying from orignal, however, we are doing things
with the car it was not designed to do and I feel that it is better
to modify and keep it alive than waste it. We do have the orignal
parts which can be reinstalled should someone wish to make a reverse
conversion.
Randy Svajda
conversion.
Randy Svajda
