Re: [HSS] 28 Hudson Oiling/Bearings
randy.beall@gte.net wrote:
On the other side of the ledger, here in New Zealand, there were>
> Hi, Paul.
> I have learned a bit about the super six engine. It is a tough
> engind, but to do the Great American Race with the orignal splash
> oiling system would be to waste a good engine. The crank has been
> drilled for oiling, hard chromed and ground to size. Main and rod
> bearings have been refitted with insert bearings. Oil lubricates and
> cools in the engine and splash is not sufficent for the high loads
> and long run times we give the cars. A race car on the track has it
> easier because of the shorter time it runs.
> I did not do the actual modification of the engine, just trouble
> shoot it and keep it working. We must do some further improvements on
> the oil pump drive and seal portion, but the basics are correct.
> We may add an oil squirter to the front cover putting oil directly on
> the auxillary shaft drive to cool and lubricate it. The orignal
> bronze part has a self lubricating effect against steel. The
> replacement steel part will need just a bit of protection.
> Just as a thought, I suspect the additional load of the oil pump on
> the auxillary shaft drive may have contributed to it's failure, even
> though they are a weak link in orignal configuration.
> I too dislike modifying from orignal, however, we are doing things
> with the car it was not designed to do and I feel that it is better
> to modify and keep it alive than waste it. We do have the orignal
> parts which can be reinstalled should someone wish to make a reverse
> conversion.
> Randy Svajda
hundreds of Super Sixes from 1916 thru 1929 which were modified to use
as Service Cars (extended chassis, and up to 16 seat bodies). Most of
these did hundreds of thousands of miles under severe condition, and
none of them had the engines modified. My own '29 Hudson 7 Pass. was
in daily use from 1929 thru 1952, averaging 250 miles per day, which
adds up to over 1 million miles. The cylinders had been sleeved back
to standard after 3 rebores, but the crankshaft was still standard,
though extremely worn. The valve guides were worn out, and the seats
had inserts but the auxilary drive was also unworn except for the
portion of the shaft where the pump seals had been tightened. All the
spring leaves were worn half way through, and the shackle pins stepped.
Rear axles broke, but the engines very rarely failed.
Geoff.
