Leaky Marvel Carbies
In a message dated 8/2/01 3:59:33 AM, lewphelps@earthlink.net writes:
<< Most of the leakage is coming from around that
plug, which seems not to seat properly even when "fully" tightened. When
I removed the plug while I was inspecting the car in Washington, there
was a thin metal washer in place. But nothing of a softer material (e.g
rubber or paper) that would have helped to seal the joint. Is something
simply missing there? >>
I don't know what should be there, but often a good close look will tell
what you need. Many carbies of this vintage used the old red fiber washers in
areas like this and they are still available from Restoration Supply <
restoration@rsc.reno.nv.us > in Reno. Often you need nothing more than teflon
tape to seal fuel joints.
On the Super Six home page Links section is a neat little page called the
Hudson Super Six Library. The URL is:
http://hudsonsuper6.tripod.com/
That neat little library page contains a PDF file on the Marvel carbys and
another one on the Stewart vacuum tanks. They may be of some use to you.
Paul O'Neil, Hudson29@aol.com
Fullerton, California USA
NEW email list for Hudson Super Six Cars, 1916-1929!
http://www.egroups.co.uk/group/HudsonSuperSix16-29
1926 Hudson Anderson Bodied Coupe
1926 Hudson Parts Car "The Grapes Of Wrath"
1928 Hudson Roadster Project
1929 Hudson Town Sedan
1939 Cadillac Coupe (How'd that get in there?)
AEROMARK - Need Rubber Stamps or Signs? See:
http://www.aeromark.net
