Re: [HSS] Oil gauge float
zkwills@aol.com wrote:
Yes, the oil float is in a tube which presses into the crankcase from>
> My oil gauge float doesn't anymore. Can I get to it by simply
> removing the oil pan? I assume it is a simple cork float dipped in
> shellac. If not, what do I need to replace it with? I would like to
> have my ducks in a row before I start the project (for once). Zeke
underneath. The float is probably saturated and coated with carbon.
I made a new float out of .003 shim brass and soldered a thin bronze
wire to it.
Geoff.
