Re: [HSS] Help! Need clutch problem cure for 29 Super Six
Did you turn it over while the keroseen was in it? Put a stick to hold the
clutch pedal down, and let it set with the keroseen in it, and turn it to a
different spot each day. KLet the stuff work. But you need the pedal
depressed to take the pressure off and let the corks swell up.
> I ALMOST have the '29 Town Sedan in shape to take out on the street.
> Fixed the carburetor leakage problem. Fixed the leaks around the water
> pump shaft. Got the exhaust system installed. Engine purrs like a
> kitten. (Well, a BIG kitten..)
> But the clutch won't work. Even with the pedal fully depressed to the
> floor, the clutch won't disengage. Test: put into first gear while
> stopped. Depress clutch to floor. Turn starter motor. Car jumps forward.
> I drained the pitiful 3 oz. remains of oil in the clutch, rinsed some
> with kerosene, and then put in the requisite 3/4 pint of Hudsonite (half
> oil, half kerosene). BTW, it's no picnic to get that plug back in, is
> is? That didn't solve the problem.
> Any suggestions what I might look at to fix this, short of total clutch
> disassembly?
> Community email addresses:
> Shortcut URL to this page:
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
