Replacement "nut" for 29 bench seat mechanism
With the help of Geoff Clark in New Zealand, I'm having a replacement
casting made for the broken "nut" that makes the front seat
adjustment mechanism work on my '29 Town Sedan.
As long as we're at it, we should be making enough to fill current
needs of this group, and maybe one or two extras for people who
develop a problem later. So...if you want one of these little
thingies, please let me know.
The original item is made of pot metal, which is why it is
vulnerable. The replacement will be cast in "gun metal," which is
type of bronze alloy. Geoff can provide details on that if anyone
needs to know. But you can be sure it will be several orders of
magnitude stronger than the original.
I propose to pay Geoff directly for all the US-bound items, and then
re-distribute to participants in the group order. I know already that
Paul O'Neil wants one, so we're for sure ordering three (one for him,
one for me, and one for safe keeping.
Cost remains to be determined, but I am guessing something on the
order of $50 to $75 per item. Geoff will let us know after he
receives the original and gets it into the hands of his casting
wizard. There will be a one-time cost for a mold to be made off the
original, and then a per-item charge for each casting. I propose to
split the one-time charge among those who order (one charge per
buyer, even if you order more than one "nut.") So if we have four
buyers, each pays 1/4 of the setup charge plus the per-unit cost for
as many units as are ordered. plus shipping costs for the
re-distribution within the US.
Just to avoid anyone else experiencing the same confusion that I
suffered on this seat mechanism problem, let me describe what the
part is and where it fits into the scheme of things.
First off, there are two different kinds of seat adjustment
mechanisms that were installed on '29 Hudsons. One kind, which went
onto Coupes and other two-seaters (I think) is a fairly elaborate
mechanism that moves the seat cushion forward and back, raises the
seat cushion up as it comes forward, and also adjust the back cushion
angle. That is NOT what we are talking about here.
The "bench seat" mechanism on my '29 Town Sedan (and I presume other
Hudsons with a front bench seat) only adjusts in one dimension --
moving the entire seat forward and back. This is a much simpler
mechanism that the Coupe has. On this version, the entire seat slides
back and forward on a track. The whole mechanism (and the seat) is
driven forward and backward by a 6" screw that is attached to the
fixed base. The screw goes through a "nut" that is attached to the
portion of the seat that slides. When you turn the screw the nut
moves forward or back, and carries the seat with it.
The "nut" is a disk about 1 1/4" in diameter and 1/2" thick, with a
stubby "axle" projecting from each sides. The "axle" fits into two
holes in the mounting bracket, and holds the "nut" in place. You have
to remove the seat cushion and then stand on your head to see this.
The mounting bracket for the "nut" is at the front of the seat, with
the adjusting screw going through it.
You will have to drill out two rivets to remove and replace the
original "nut" and put in a new one, and then re-rivet. Installation
should be easy.
I'll post a photo of the "nut" if anyone is uncertain about what
we're talking about.
Lew Phelps
Pasadena, CA
1929 Town Sedan
should be easy.
Lew Phelps
Pasadena, CA
1929 Town Sedan
