Re: [HSS] Oil pressure/pressure gauge
In a message dated 10/16/01 8:26:38 AM, lewphelps@earthlink.net writes:
<< My first presumption is that the gauge itself is bad, or the sender line
clogged. I am thinking that I could check this by going to the local
Auto Zone and buying a low-cost analog (mechanical) oil pressure gauge,
and just disconnecting the fitting on top of the oil pump (the small
copper tube leading to the oil pressure gauge) and connecting the new
gauge temporarily, right under the hood. Any reason to think that
wouldn't work? >>
Gauges built for pressurized motors may not be sensitive enough to read
the low pressure that these old Super Six motors run on. The gauge Hudson
used runs to 5lbs or so, the typical SW mechanical gauge runs to 60lbs. Has
anyone tried a modern gauge?
Paul O'Neil, Hudson29@aol.com
Fullerton, California USA
NEW email list for Hudson Super Six Cars, 1916-1929!
http://www.egroups.co.uk/group/HudsonSuperSix16-29
1926 Hudson Anderson Bodied Coupe
1926 Hudson Parts Car "The Grapes Of Wrath"
1928 Hudson Roadster Project
1929 Hudson Town Sedan
1939 Cadillac Coupe (How'd that get in there?)
AEROMARK - Need Rubber Stamps or Signs? See:
http://www.aeromark.net
wouldn't work? >>
