Re: [HSS] water pump
jjt39378@webtv.net wrote:
John, many years ago one was able to buy small tins of water pump>
> Hello once again
> Could someone please tell me what is "hard grease" for the water pump
> on my 1927 Hudson and what would I replace it with now ?
> thank you
> John T
grease, which was a sodium soap based grease which did not soften in hot
water. Unfortunately in these days of permantely sealed
maintenance-free water pumps, this product is no longer easily
obtainable. However, in my opinion it is actually not needed in Hudson
water pumps in any case. You will not in your '27 Hudson that there
is no provision for lubricating the front bushing anyway, so why bother
with the back one. As mentioned in previous emails, I use graphite
string packing with a smear of moly-slip for the packing, and I also put
a pint of soluble oil in the radiator (as used in lathes, ginders, etc),
and in 30 years of motoring a super six have no occasions of the water
pump bushings wearing. The soluble oil in the water is enough to
keep the bushings lubricated. Probably this is not needed at all, as
most Hudsons run without this, and never get grease in the water punp.
However, I know of one instance where a car was driven in and out of the
garage several times without water in the system, and the water pump
shaft seized on to the bronze bushing, so this proves the theory in my
opinion, that water is enough. I think actually that a good long
packing of graphite string acts as more of a bearing than the actual
bushing.
Geoff.
