Re: [HSS] Lube Job - The Other Steering Knuckle
Hudson29@aol.com wrote:
Paul, those joints look as dry as a drover's throat. I lube my>
> Here is a shot of the other side. This tie rod end also took a couple of
> turns to snug up the nut. Both front wheel hubs needed a small amount of
> tightening, I guess the wooden spokes has shrunk some over the 75 years this
> car has been wandering the highways.
> Fullerton, California USA
steering joints every 500 miles with 600 weight gear oil. Makes a mess
(which can be wiped off), but sure prevents wear.
Geoff.
