Rear axle oil seals.
To save members the hassle of measuring, I have just installed modern
oil seals in the rear axle of my '29 Hudson. The inner seal (right
inside the housing next to the diff gears, is CR13569. To fit this you
will have to pack around the outside of the seal, and this is easier of
course if you have the gearset out. I used a soup tin with corrugated
sides (circumferentially). Cut out a section of the corrugated part
and wrap around the seal to get a fit, then insert this packing in the
housing, and using a little gasket compound or loctite, etc, as a seal
around the outside, press the seal into this. For the inner seal of
the axle outer ends, use CR17484. The original seal retainers were
held in place by punching the housing with a dot punch, and where the
housing is distorted you will have to grind out with a small rotary
grinder to get these burrs out, and grind a slight chamfer in the
housing. The 17484 seal is a perfect tight fit in the housing. Hope
this is of help.
Geoff.
this is of help.
Geoff.
