The Coupe Is Out!
This past Saturday was the final day that was available to get the '26
Hudson Coupe ready for the Laughlin Economy Run. As Geoff and Randy had
suggested, the mixture adjustment turned out to be very easy to do. The big
knurled knob readily turned with a screwdriver and at either end of 5 or so
turns made the engine run rougher and slower. I left it somewhere in between.
The motor does run better.
Sad to say, there is a persistent miss that was unaffected by the mixture
changes. The motor misses, runs rough and "hunts" at idle. I shorted the
plugs one after the other with a screwdriver, all had a good fat spark. I
don't think it misses except at idle, Jeff, you rode in the rumble seat at
San Simeon, how did it sound? Anybody have any ideas on what to check next?
The miss is annoying, but the fatal problem for the Economy Run was the
fan hub bearing. The last several drives I have been hearing a squealing
sound from the motor. It was only evident at speeds over 30mph. The faster
the car goes, the louder the noise. Saturday I revved the motor fast enough
at a standstill to confirm that the noise was coming from the fan hub
bearing. It seemed a simple matter to grease the hub and silence the bearing,
but the noise is still there after two good sessions from the grease gun.
Something is dry up there and I fear that the hub may seize or ever come
off at speed. It looks like the radiator will have to come off to get at the
hub and there is just not enough time left to do this before the trip. Any
suggestions on getting this hub shipshape?
Well, you other competitors caught a big break with the old Super Six out
of the running this year (it was sure to take first place for the most gas
used), but like the Cubies fans say, "just wait till next year!"
Paul O'Neil, Hudson29@aol.com
Fullerton, California USA
NEW email list for Hudson Super Six Cars, 1916-1929!
http://www.HudsonSuperSix16-29@yahoogroups.com
1926 Hudson Anderson Bodied Coupe
1926 Hudson Parts Car "The Grapes Of Wrath"
1928 Hudson Roadster Project
1929 Hudson Town Sedan
1939 Cadillac Coupe (How'd that get in there?)
AEROMARK - Need Rubber Stamps or Signs? See:
http://www.aeromark.net
