Re: [HSS] clutch return spring
Robert Bartosch wrote:
Geoff. >
> Geoff
> Do you know if the clutch on the 1916 that you are looking at with
> Peggy is the same for a 1920 Super Six. I ask because I have a '20
> w/o the large clutch return spring housed in the rear main bearing of
> the crank shaft, and as long as you were looking for Peggy you might
> also find a spring.
> Thanks
> Bob Bartosch
>The parts we have came from a cache of stuff left over after the restoration of a 1918 Hudson, but there was apparently only one genuine 1918 clutch, and that is on the car. We have lots of later clutches, but none of the earlier ones with the spring in the crankshaft, sorry.
