Re: [HSS] Anyone need a "seat adjustment nut" for their 29 SS?
Hudson Town Sedan wrote:
You are right about not suiting other models. The Hudso and Biddle &>
> I've found a machinist n Pasadena, CA who says he can manufacture a
> replacement "nut" for the seat position adjuster on my '29 Town Sedan.
> If others want one, now is the time to say so! (Paul: I assume you're
> "in" for this project.)
> I don't have a cost estimate yet, but it's clear that the more people
> who participate, the lower the per-unit cost. They guy has to make a
> thread cutting tool to cut the threads into the disk (4 TPI square
> thread...not Acme thread as I had thought earlier). I think we're
> talking about roughly $50 per item, unless we get quite a few
> participants, in which case it will be less.
> They will be machining this item out of brass, which should be a whole
> lot stronger than the pot metal that came OEM. The machinist has the
> "screw" from my car to make sure the threads he cuts into the stock
> are a proper fit.
> If you have a '29 with an adjustable seat, this would be a smart
> investment. That pot metal "nut" is going to break sooner or later.
> Why not replace it?
> (BTW, this is not appropriate for all '29 models. Some -- I think the
> two-seaters -- have a completely different mechanism. But if your
> front seat "only" slides back and forth (but not also adjust in height
> at the same time) this is for you.
> Photos of the original (and broken) piece are online at
> http://homepage.mac.com/lewphelps/PhotoAlbum3.html.
> Lew and Cathy Phelps
> Pasadena, CA
> 1929 Hudson Town Sedan
> http://home.earthlink.net/~lewphelps/hudson_29/
Smart bodies have a completely different mechanism, so it looks like a
Briggs exclusive. Glad you have been able to get this machined, as
when I took it to the foundry he said it wouldn't work out very well
because of shrinkage in the process.
Geoff.
