fan belt length on 29 SS?
Does anyone know the proper length for the fan belt on the 1929 Super
Six engine? The belt that came with my Town Sedan (brand new, installed
by prior owner) is 42 inches circumference. this is almost certainly too
small, since even at the most relaxed setting of the fan belt tension,
it isn't loose enough to pass the test described in the service manual
(that is, to be able to pinch the belt between thumb and forefinger, and
have the gap close to about 1 inch to 1/2 inch).
I have had a lot of noise from the fan bearing. I took it off and
cleaned it, then reassembled it. But I don't want to reinstall until I
have the right belt size.
Also, it appears that there's not sufficient clearance to get the fan
off its shaft unless I remove the four blades. Am I missing something
here?
Lew Phelps
Pasadena, CA
1929 Hudson Town Sedan
http://home.earthlink.net/~lewphelps/hudson_29
here?
Lew Phelps
Pasadena, CA
