More on mysterious engine problem
I think I have an electrical problem. Here's why: when I first turn on
the ignition switch, the gas gauge reads empty. If I advance the spark
retard to maximum retard, the meter comes alive. If I reduce the retard,
the gauge goes back to zero. Once the car starts, I can reduce the
retard and it runs fine, with the gas gauge staying in the "on" position.
BTW, I also have a problem with the gas gauge. It reads 1/4 tank no
matter what the gas level. Stuck float? Electrical short connected to
the above problem?
I'm setting out very shortly to do a complete rewiring of the car, with
a harness purchased from YnZ Yesterday's Parts. If there's a short (and
that is not improbable given the overall condition of the wiring), I'll
fix it with that. But how do I access/remove/service the float level
in the gas tank?
Does this provide clues to anyone?
Lew Phelps
Pasadena, CA
1929 Hudson Town Sedan
http://home.earthlink.net/~lewphelps/hudson_29
the above problem?
in the gas tank?
Lew Phelps
Pasadena, CA
