Thank yous & more questions
Hi, First I would like to thank Alex, Lew and Paul for there help and
answers to some of my questions. Everything was very helpful. In
answer to some of your questions, the car is a standard sedan with
dual sidemounts and a trunk. The interior looks original with the
exception of the headliner which looks newer but of of the same
material. I live on St Simons Island in Georgia which is half way
between Jacksonville, Fla. and Savannah, Ga.
Since my first message, I have had a chance to look at a few more
things on the car. I have removed and have been cleaning the
carburator. It is amazing what sort of surprises you find when you
start to remove the layers of dirt,etc.. from something. In the case
of my carburator the first surprise came when I touched the bottom of
the carburator and the nut below the low speed nozel broke off in my
hand. Later investigation showed that it had been "glued" back on and
that the hole had been filled with gasket sealant. I can't believe
that it didn't leak. Lew, I thought of your experience with the inlet
connection breaking off because mine has a small section missing. The
next surprise came when I started to clean the bowl section and I
discovered that the bowl cover had been replaced with a piece of
clear plexiglass which was falling apart. The thing was in such bad
shape that I can't even use it for a template to make something new.
Lew, I looked at the photo of your carburator on your web site and it
looks different than mine. Mine looks like the one in the Marvel
Carburator manual that I found on the Hudson Library site. I am
wondering if mine is correct for the year or not? The only numbers I
can find on the bowl body are 65-68 and a small Alemite logo. I can
probably fake a new bowl cover but I might be better off ordering a
new bowl from the guy that you recommended but I am not sure that it
would fit my carb.
I have also taken apart the distributor and I believe that I see
where the ignition switch is supposed to hook up. Does it connect to
the two screws located on the underside of the distributor plate?
As always I am running out of time to finish this message so I will
ask just a few more questions:
Can I bead blast the carb bowl or do I risk it falling apart?
Paul, You mentioned that a Chevy Six condensor would work. Did Chevy
use the same one for a long time or am I looking for a '29 Chevy six?
Can I get one of these from a NAPA place or do I have to find a
vintage Chevy parts place? Do have a part #?
How do I remove the interior door and window handels so that I can
take off the door panel? I do not want to break them so I want to
make sure I know how before I try. Do I need a special tool for this?
I have photos of the car if anyone is interested. I will try to post
them to the site later.
Lew, I will be in contact with you since I definitely would like a
copy of the manual and info that you have on CD.
Thanks again to everyone for their help. Pace
would fit my carb.
