Re: [HSS] John, One more question
Pace, no, I have not included the cover, but could get a price for these
when I pick up bowels.
John.
John.
----- Original Message -----
Sent: Wednesday, February 06, 2002 9:32 AM
Subject: [HSS] John, One more question
> Hi John, I forgot to ask you if your carb bowel contains the cover as
> well or if it is just the lowel section? thanks, Pace
> --- In HudsonSuperSix16-29@y..., "John Meadows" <meadows@d...> wrote:
> > Pace, the Marvel carb bowel that you have is the correct one for
> your car
> > Pt. No. 65-68.
> > I am picking up the castings from the foundry next week. For the
> others on
> > the list that are
> > interested in this project I have found the sand castings were not
> > satisfactory and have had
> > them made from the lost wax process. Price will increase by about
> 20% but
> > will have a better
> > casting.
> > John.
> > From: coffeepace <pace64@b...>
> > To: <HudsonSuperSix16-29@y...>
> > Sent: Wednesday, February 06, 2002 5:16 AM
> > Subject: [HSS] Thank yous & more questions
> > > Hi, First I would like to thank Alex, Lew and Paul for there help
> and
> > > answers to some of my questions. Everything was very helpful. In
> > > answer to some of your questions, the car is a standard sedan with
> > > dual sidemounts and a trunk. The interior looks original with the
> > > exception of the headliner which looks newer but of of the same
> > > material. I live on St Simons Island in Georgia which is half way
> > > between Jacksonville, Fla. and Savannah, Ga.
> > > Since my first message, I have had a chance to look at a few more
> > > things on the car. I have removed and have been cleaning the
> > > carburator. It is amazing what sort of surprises you find when you
> > > start to remove the layers of dirt,etc.. from something. In the
> case
> > > of my carburator the first surprise came when I touched the
> bottom of
> > > the carburator and the nut below the low speed nozel broke off in
> my
> > > hand. Later investigation showed that it had been "glued" back on
> and
> > > that the hole had been filled with gasket sealant. I can't believe
> > > that it didn't leak. Lew, I thought of your experience with the
> inlet
> > > connection breaking off because mine has a small section missing.
> The
> > > next surprise came when I started to clean the bowl section and I
> > > discovered that the bowl cover had been replaced with a piece of
> > > clear plexiglass which was falling apart. The thing was in such
> bad
> > > shape that I can't even use it for a template to make something
> new.
> > > Lew, I looked at the photo of your carburator on your web site
> and it
> > > looks different than mine. Mine looks like the one in the Marvel
> > > Carburator manual that I found on the Hudson Library site. I am
> > > wondering if mine is correct for the year or not? The only
> numbers I
> > > can find on the bowl body are 65-68 and a small Alemite logo. I
> can
> > > probably fake a new bowl cover but I might be better off ordering
> a
> > > new bowl from the guy that you recommended but I am not sure that
> it
> > > would fit my carb.
> > > I have also taken apart the distributor and I believe that I see
> > > where the ignition switch is supposed to hook up. Does it connect
> to
> > > the two screws located on the underside of the distributor plate?
> > > As always I am running out of time to finish this message so I
> will
> > > ask just a few more questions:
> > > Can I bead blast the carb bowl or do I risk it falling apart?
> > > Paul, You mentioned that a Chevy Six condensor would work. Did
> Chevy
> > > use the same one for a long time or am I looking for a '29 Chevy
> six?
> > > Can I get one of these from a NAPA place or do I have to find a
> > > vintage Chevy parts place? Do have a part #?
> > > How do I remove the interior door and window handels so that I can
> > > take off the door panel? I do not want to break them so I want to
> > > make sure I know how before I try. Do I need a special tool for
> this?
> > > I have photos of the car if anyone is interested. I will try to
> post
> > > them to the site later.
> > > Lew, I will be in contact with you since I definitely would like a
> > > copy of the manual and info that you have on CD.
> > > Thanks again to everyone for their help. Pace
> > > Community email addresses:
> > > Post message: HudsonSuperSix16-29@o...
> > > Subscribe: HudsonSuperSix16-29-subscribe@o...
> > > Unsubscribe: HudsonSuperSix16-29-unsubscribe@o...
> > > List owner: HudsonSuperSix16-29-owner@o...
> > > Shortcut URL to this page:
> > > http://www.onelist.com/community/HudsonSuperSix16-29
> > > Your use of Yahoo! Groups is subject to
> http://docs.yahoo.com/info/terms/
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
