Re: [HSS] One more ignition question
hudsontownsedan@earthlink.net wrote:
You onviously have resistance somewhere in the circuit from the>
> We measure about 4.7 volts at the primary of the ignition coil. Is
> that correct? Why shouldn't it be full battery voltage?
> Lew Phelps
> Pasadena, CA
> 1929 Hudson Town Sedan
> http://home.earthlink.net/~lewphelps/hudson_29
ammeter/ignition switch/coil. Check that all connections are tight
and clean. You must have full battery voltage here or you will have
hard starting and erratic running. Try putting a jumper across the
switch terminal and see if this brings voltage up. If so the switch is
crook.
Geoff.
