1929 Ignition & Light Switchs
Hi, I am in the process of rewiring my 1929 Sedan and I have
discovered that both the Ignition switch and the lighting switch are
bad. Does anyone have any suggestions for replacement parts? Is
anyone reproducing copies of the originals or is there a good
substitute for replacing these?
None of the swiches on the steering column are working including the
horn. How do you remove the different parts to gain access to this
area?
Thanks for your help, Pace
area?
