1929 Wiring Question
Hi, thanks to everyone for the help and answers to previous
questions. I have fixed the light switch and horn, now I need to
solve my ignition switch problem. Lew, you mentioned using a toggle
switch. This is what I would like to do. My question is if I use a
basic on off toggle switch, what wires need to go where? The original
electrolock had three connecting screws with wires and also the
internal piece that ran to the two screws at the bottom of the
distributer. I am wondering how I need to wire everything. here is
what I have:
One wire from a switch connection to the + coil and another wire
from the same pole to the gas gauge
One wire from a second connection on the switch to the - coil.
One wire from a third connection on the switch to the ammeter.
The internal switch piece that runs from the electrolock switch to
the distributor plate.
can anyone tell me how to rewire these using an on off toggle switch?
or some other similar alternative. thanks for the help, Pace
what I have:
