Re: [HSS] Correct routing for coil wires?
In a message dated 3/28/02 8:34:31 AM, hudsontownsedan@earthlink.net writes:
<< correct routing of the coil wires as they go aft from the coil
to the firewall? Do they route inside the protective tube that carries
the spark plug wires, or do they route outside of it? If outside, where
are they placed/anchored/tied down? >>
On the '28 & '29 Super Sixes, the clip that holds the spark plug wire looming
tube has two positions. The lower larger spot holds the spark tube, the upper
smaller position holds the armored Electro Lock cable. The primary wires
route through this armored cable from the dash switch all the way to the
distributor interior.
Paul O'Neil, Hudson29@aol.com
Fullerton, California USA
NEW email list for Hudson Super Six Cars, 1916-1929!
http://www.HudsonSuperSix16-29@yahoogroups.com
1926 Hudson Anderson Bodied Coupe
1926 Hudson Parts Car "The Grapes Of Wrath"
1928 Hudson Roadster Project
1929 Hudson Town Sedan
1939 Cadillac Coupe (How'd that get in there?)
