Annual Sump Cleanout?
In a message dated 4/10/02 2:20:12 PM, geoffclark@xtra.co.nz writes:
<< Hey, they are not supposed to do that. [ LEAK OIL OUT OF THE REAR MAIN ]
Either you have a bad gasket,
or the oil return pipe is blocked, or it is cracked where it exits
through the pan flange. Usually the solder breaks away around the
join. It can be fixed without removing the pan by using the trusty
silicone gun. >>
It used to be considered SOP (standard operating practice) to remove the
pan once a year for cleanout and inspection. Is there any reason to do this
nowadays? Our modern oils keep things pretty clean even without a filter. I
have been thinking of fixing the leak on the '29 and having a look at the
bottom end at the same time.
Paul O'Neil, Hudson29@aol.com
Fullerton, California USA
NEW email list for Hudson Super Six Cars, 1916-1929!
http://www.HudsonSuperSix16-29@yahoogroups.com
1926 Hudson Anderson Bodied Coupe
1926 Hudson Parts Car "The Grapes Of Wrath"
1928 Hudson Roadster Project
1929 Hudson Town Sedan
1939 Cadillac Coupe (How'd that get in there?)
silicone gun. >>
