Re: [HSS] Questions
Attachments :
Not often I can reply with any information of value, and this may be the day
either!
Death Wobble. Sounds like a heavy duty belly dancer! A friend had the
same problem (not on a Hudson) and it turned out to be mainly to do with the
absence or incorrect installation of a little wedge plate needed to provide
the right castor angle for the entire front axle. But this guy is really
slack - he also had wrong tyre pressures and no shock absorbers. The latter
weren't strictly necessary but they can help.
Advance Lever. Sounds as though the sliding block and spring may be
missing. Have a look at the hand throttle control - the mechanism is the
same. I made up these bits - filed and ground at a piece of
bakelite/plastic to get the right shape and just shortened a spring I found
in the local hardware place.
35 x 5 Tyres and Tubes. I bought a set of four about 18 months back here in
Australia, and they're still available. Expensive, but isn't almost
everything? The pic attached shows one of my racer wheels fitted with BF
Goodrich tyres. The rim isn't original but my budget couldn't handle having
locking ring-type rims manufactured. You should also think very hard about
"dust bands" that sit inside the rim and protect your tube from dust/dirt
entering via spoke holes, valve or wherever. If you have wire wheels they
also provide a degree of protection against any sharp spoke ends that
haven't been fully ground down.
either!
----- Original Message -----
Sent: Tuesday, April 16, 2002 5:03 PM
Subject: [HSS] Questions
> Hi Guys
> Having overcome my lack of vacuum tank for a fuel supply by cobbling
> together a regulated fuel pump I now have the car running ok. I now need
to
> remedy a few other items. I wish to get the lights working and cannot get
> the bezel of the headlamp. Is there a method which I have missed before I
> get heavy handed ?
> Secondly I have a 'death wobble ' on the fromt end if I hit the wrong sort
> of bump and the only way to get control is to stop completely.
> This car spent some time in Canada and some of the work done on it appears
> to have been 'substandard' or at best misunderstood. Is there some
geometry
> settings out there for King Pin inclination which may solve my problem?
> The ignition sounds very retarded even when full advanced even though it
> appears set 'to the book'
> The advance lever appears to have something missing out of the end of it
> which would afford it some resistance as it falles staright to retard when
> running if not held up!
> I have no crank handle, are these available or is it time to make one?
> The motor will not start on 6 volt due to lazy cranking and sod all volts
> left at the coil but on 12v starts instantly. Generator output is 6.8
volts
> at 1000 rpm
> Finally availability of tyres and tubes 35x5 will import from US if needs
> be..???????
> Still hunting for a vacuum unit, found a tank but no 'gubbins' inside it
> and the top casting is wrecked
> Cheers
> Martyn
> Community email addresses:
> Shortcut URL to this page:
> Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
