Re: [HSS] Iron Poor Tired Springs?
Hudson29@aol.com wrote:
Any reputable wheel alignment shop should be able to check the caster>
> In a message dated 4/19/02 2:20:44 PM, geoffclark@xtra.co.nz writes:
> << As the springs sag, then the caster
> usually increases, and this is the cause of the problem. By rebuilding
> the front springs, and restoring the caster angle, the problem has been
> cured. You can avercome it by the judicious use of wedges >>
> Are there any specs on this? How do we tell if the springs are sagging
> anyway? Perhaps we should compare fender clearance differences on our old
> buses with the appearance on photos of factory new cars? Check fender
> clearance - that sort of thing?
> Fullerton, California USA
for you, and it's just a case of wedging under the spring to get the
right amount. 1 to 2 deg positive is usual. On '29 Hudson the springs
should be almost flat, but earlier models had a bit of upward curve.
Geoff.
